Mark944na86's Avatar
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
removing starter on '89 S2
I've got my car on stands, trying to get the starter out so I can bleed the clutch, and, according to clark's garage, I should be expecting to remove the starter held on by two 19mm bolts.
Instead, I find one standard 19mm bolt on one side, and on the other side I find a socket headed bolt that looks like it needs a big allen key to fit it. Except I don't have an allen key big enough to fit it. Here's the pic:
OK, so what have I got here? Is this standard on an '89 S2? What size Allen key will fit this bolt?
Thanks for any advice,
-Mark
Currently 1990 944 S2, Black on Linen, 17" Turbo Twists
Old 04-06-2005, 03:54 AM
Feelin' Solexy
Tishabet's Avatar
Not standard as far as I know, I've got an 89 NA and mine definitely has traditional bolts that hold the starter in place.
Grant
1974 Vespa Rally 200, 1974 Vespa Primavera 125, 1963 Solex 2200, 1938 Buick Special, 2008 Mini Cooper S, 2010 Mazda CX-9, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar - in the stable
1989 Porsche 944, 1973 VW Beetle - gone but not forgotten
Old 04-06-2005, 04:31 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson Send a message via AIM to bryanthompson Send a message via Yahoo to bryanthompson
That's kindof odd... If you can get a set of large allen wrenches, then find out what size you're dealing with, you can get an allen key socket to fit that... I think that'd be the best way. Otherwise, I'm not sure you could get enough leverage with just an allen wrench and you're less likely to strip it with a good socket. The socket will probably cost about $22 from snap-on
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 04-06-2005, 05:35 AM
It's not odd. I have the same set up. The allen size is the biggest in a set of metric allen wrenches maybe a 10 or 12mm.
1993 964 C2 still makes me smile
1996 318ti (280k miles)
2011 Silverado for hauling (32k miles) - SOLD
2018 Suburban Z71
Old 04-06-2005, 08:13 AM
