-   -   Hissing sound when engine running - even at idle.. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/214933-hissing-sound-when-engine-running-even-idle.html)
dave944-87 04-06-2005 05:40 PM
I seem to have a "hissing" sound coming (not loud) from the 944 when I drive it, and still when I idle. It is difficult to tell where it is coming from.. sounds like it may be underneath the car.
I have noticed that the car smokes a little more than normal from the exhaust.. I'm pretty sure it's not a broken hose as most of them they have been checked/replaced recently.
Any ideas? Could this be a transmission issue perhaps?
TCMdocs944 04-06-2005 05:45 PM
Vacuum leak?
Balance belts normal whine?
Are you having any other symptoms or just the hiss?
If your idle is high (over 950) it is probably the vacuum
fast924S 04-06-2005 06:13 PM
AHH, I hate noises like that, I still am trying to find a hissing metalic rattle that only happens on decel, I have been chasing it for 2 years. Good luck. It might be a heat sheild or a exhaust leak
dave944-87 04-06-2005 06:17 PM
Everything else seems ok.. but when I drive down the road I don't sound a smooth porsche!
It's loud as in you don't hear it in traffic or busy area, but if you drive down a quiet residential street it is quite noticeable.. (oustide the car).
What's the "balance belts normal whine?"
fast924S 04-06-2005 06:25 PM
Kinda sounds like a light supercharger wine
dave944-87 04-06-2005 06:26 PM
Well, it's not a turbo..?
