auh auh is offline
auh's Avatar
Send a message via AIM to auh
low temp thermofan switch
There are a lot of different types of these and I was wondering what the low temp one is...
Does 82 degrees sound right? cause that was the lowest temp switch I found but it doesn't sound that much lower than the 92 degree one.
I ask cause idk what is normal temp, low temp, etc.
1974 914 1.8 Sold...
1984 944 my baby...more of a pain in the @$$ than takin' it with a cucumber, but I still love it. THE CAR YOU PERVS!!!!!!!!!!!!
1990 Nissan 240sx fastback aka Japanese 944
Old 04-06-2005, 09:33 PM
SoCal Driver's Avatar
Celsius not Fahrenheit. Your thermostat has to match too.
You can't trust the dash gauge. Bad grounds at the engine and for the gauges can throw it off.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-06-2005, 09:58 PM
Not fer nuthin, but installing an indicator light across the thermofan switch acts as an excellent "indicator" as to when the fans are on or off. Light lights when the fan is off and goes off when the fan is activated. Iused a relay to provide the "switching" so when the ignition was off, no power to the relay, opens up, and therefore no continuity to the "indicator" Worked like a charm!!
Just an indication of my paranoia....
Bob S. former owner of a 1984 silver 944
Old 04-06-2005, 10:17 PM
auh auh is offline
auh's Avatar
I have checked everything so I know that its working...I just need to know the Temp of the low temp switch
Old 04-07-2005, 10:43 AM
Hpe you are not confusing the later two element radiator temp switch with the early single element switch.
Old 04-07-2005, 01:52 PM
