Send a message via AIM to operationcougar
924 rear under a 944
how much work will it be to replace the rear suspension and half-shafts out of a 944 and replace them with components from a 924, will this work properly with given components, or am i missing something?
95 - BMW 740i (daily driver)
02 - kawasaki mean streak (nice weather driver)
RX-7 built of other RX's (and a good place to throw money) (sold)
z31 300zx vg30det+ (new money sucker)
Old 04-07-2005, 11:33 AM
Send a message via AIM to AznDrgn
why would you do that? it's a downgrade unless you are talking about a 924S. 924's have non self adjusting drum brakes in the rear which are a HUGE PITA. Unless you have an early 85 the half shafts are different and the offsets will be different too.
'91 Jeep Cherokee 4.0L HO - Daily driver
'83 Callaway 944 2.5L turbo - Soon to be daily driver
'83 Porsche 944 NA - sold
'78 Porsche 924 NA- RIP
'89 Porsche 944 S2 - Parted
Looking for a nice 944S for a daily driver.
Old 04-07-2005, 11:42 AM
sorry, you missed my point, what i was wanting some serious meat on the wheels, if im thinking right with very simple modification to the wells, ill be able to get some huge rear tires in there
Old 04-07-2005, 11:47 AM
Do you have an early 85 or late 85? Either way roll the quarter panel lips. Then if you have a late car get early rims and some spacers so they don't rub on the inside and then you should be able to run 10's without them sticking out and looking totally stupid. Now here's the big question. What do you need serious tires under the rear end for? You probably already have more tire than your engine can handle.
Old 04-07-2005, 11:52 AM
really it was going to be just the looks of the car, its a late 85, and ive got a buddy who works at a tire shop and they do a lot of special orders, and i can remmeber a preticullar 944 with some very wide tires under it in the back, it looked great, and he says it was a new expeariance to drive-very fun
Old 04-07-2005, 12:18 PM
well like I said just roll the lips, adjust the offset and you should be able to run some 9's or 10's back there without any trouble.
Old 04-07-2005, 12:22 PM
ill look into that, seems cheaper and easier, thanks for the info, and bringing me back to reality
Old 04-07-2005, 01:32 PM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
It's all about the offset of the wheels, don't adjust your suspension to the wheels - that's REALLY expensive! Adjust the wheels to the suspension you have!
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Old 04-07-2005, 01:38 PM
Non Compos Mentis
I've had 255's in the rear, and there's still a bit more space.
The car is much more fun to drive, however, with same size tires front and rear. A bit of oversteer is fun, and huge amounts of rubber in the rear eliminates any drifting. Just induces understeer.
Yeah, wide tires LOOK great, but unless you have some serious horsepower figures, they are for looks only.
Old 04-07-2005, 01:48 PM
SoCal Driver's Avatar
What is it about 50/50 weight balance you don't understand?
It never fails to amaze me to take a right turn at 40 mph and stay in the outer lane. Did it today with this ricer dude on my behind. Should have seen the look on his face when he went sideways into the inner lane! Stock 15" rims and tires.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-07-2005, 01:57 PM
Rmills944's Avatar
what about oversteer and rear wheel drive dont' you understand?
Just cause you have 50/50 weight doesn't mean ****. Yes, it makes a more balanced car and it's easier to control, but you still have oversteer in a 944. If you haven't swung the back end around, you haven't tried very hard. Any rear wheel drive car will oversteer - which me and most track drivers would prefer since you can tighten up a turn using the gas pedal.
A front wheel drive car does the opposite and understeers - or the front wheels loose grip first. This makes the car not turn as much as you think it will - a very bad thing, and you can't as easily correct it.
They offered 7" fornt and 8" rear fuchs as an option - ever wonder why?
Ryan
Old 04-07-2005, 02:32 PM
Guess I should have prefaced the reply with "operationcougar,".
Old 04-07-2005, 02:38 PM
i have a 700hp nissan ill keep to the track and city stoplights, i have a 944 to have fun in and i have a alero to bore my self to death in, and my town knows about it all
Old 04-07-2005, 03:17 PM
Non Compos Mentis
The optional 7 & 8 Fuchs still had 215/60/15 tires both front and rear.
They were the same wheels that were used on the 911 at the time, that needed more rubber in the rear because of the 911s rear weight bias.
Old 04-08-2005, 07:12 AM
