bryanthompson's Avatar
Send a message via ICQ to bryanthompson Send a message via AIM to bryanthompson Send a message via Yahoo to bryanthompson
Crank gear questions
Hey guys. I got my water pump on alright, and I'm working on getting the crank gear on, but I have a quick question. Is there supposed to be _any_ space between the two front gears on the crank? Right now the bolt is almost tensioned down completely and I can feel maybe 3/16" of space between the teeth on the back gear and the back of the front gear. It seems a little off.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 04-07-2005, 11:37 AM
SoCal Driver's Avatar
Hmm.. Here is a parts picture. I had the impression there was a spacer in there. Then maybe not.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-07-2005, 02:25 PM
You woodruff key may have jammed.
Old 04-07-2005, 02:26 PM
I think it's okay. #15 in your diagram has a groove in it that stops it from going in too far, so it's where it should be. It kindof seats itself there.
She's all back together, except for the balance belt. I have to leave the balance belt off until I can get/find a new nut for the tension roller -- I accidentally stripped one.
Old 04-07-2005, 04:00 PM
AFJuvat's Avatar
Bryan,
The nut is an M-10 lock nut. You should be able to get one at a hardware store. However, a plain old regular nut will not be suffucuent for what you are doing.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 04-08-2005, 04:46 AM
