Front brake pads stuck
On both sides the outboard pad is stuck bad. Inboard pad came out easy. On the other I've pried, whacked, etc and it doesn't budge. Any secrets?
1985 (early) 944
Old 04-08-2005, 07:15 PM
SoCal Driver's Avatar
You have pried the pads away from the rotor? Sometimes the lip on a worn rotor can keep the pad from coming out. Your pad/cylinder carrior may also be hung up. This should be taken apart and cleaned so it moves as intended.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-08-2005, 07:51 PM
What do you clean the seals with? What lubricant?
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 04-09-2005, 04:10 AM
Lawrence, what seals do you mean? This is the first time I've touched the brakes on this car.
1985 (early) 944
Old 04-09-2005, 05:14 AM
These are the seals on the pistons of the caliper. Mine are not sticking but I would like to know what to use to clean them. The pistons come right out quite easily. I'm sure SoCal knows.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 04-09-2005, 05:54 AM
Silicone lube. Make sure the brake pads are out of the way or you will have lubed pads. Degrease/clean the rotor with the carb/brake cleaner stuff. I've never had any problem with the rubber covers. In fact I've never had a sticking disk brake cylinder.
What I have found is the floating carrior to be rusted and some what reluctant to move back and forth as it should. Had the pads wear to a wedge shape on one wheel. Was taking it apart to do the bearings when I found the pads. Took the pads over to the belt gringer and reshaped them, put them back on and test drove the car. Took care of the bad bearing sounds. Obviously time to take it all apart and do some cleaning. Replace the rotors and pads too.
Old 04-09-2005, 08:10 AM
The outboard pad is secured by a lug on the sliding part of the caliper. What's happened is you are trying to force the pad out without levering the caliper slider away from the pad. Look at the new pads and you will see a rectangular hole in the pad..that's where the slider fits.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 04-09-2005, 08:35 AM
What he ^^^^^ said.
Old 04-10-2005, 10:11 PM
