Carpet
My interior carpet is disgusting and faded. What can be done. Can it be removed and re dyed? Or should i just replace it entirely?
Has anyone done this???
Chip
83 944na
Old 04-11-2005, 03:21 PM
SoCal Driver's Avatar
Get new carpet. Old disgusting carpet just looks like new disgusting carpet if you dye it.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-11-2005, 03:28 PM
my924gtc's Avatar
I've done it a few times. Go to World Upholstery they have it all and are great people to work with.
Old 04-11-2005, 03:32 PM
entertaining the idea
UconnTim97's Avatar
I replaced mine last year....made a world of difference.
It wasn't that difficult of a job, My dad and I did it in one day.
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 04-11-2005, 05:29 PM
kg_p944
Guest
Posts: n/a
Did you go with "molded" or "cut and bound"? How much of the dash (if any) did you have to remove?
Old 04-11-2005, 05:32 PM
my924gtc's Avatar
I've done both molded and C&B. Depends on what you are going for. If you want a 100% stock look go molded. I like the stripped out look without any sound deadening pads or insulation so I prefer cut and bound.
I've also done both OEM German and Domestic Loop and again it depends on your intentions. The domestic stuff is still pretty good carpet just does not look the same as your original carpet.
Get the carpet and a couple cans of 3M trim adhesive and go to town. Should take a day or so if you stick with it. The seat back and all the buttons around the hatch area are the most time consuming parts of the install.
Old 04-11-2005, 05:52 PM
My carpet/sound deadening was in poor condition, I replaced the sound stuff with dynamat and carpet padding, used the carpet kit from Original Fit Interiors (Fair, no better, no worse), and it took me about 12 hours. I have an early.
1983 944 with S2 motor, trans, suspension and exterior -- crunched parts car
1987 944 -- soon to be 1987 944S2
Old 04-11-2005, 06:55 PM
