strath44's Avatar
Fuel Line leak....
What a pain put the old girl up on the ramps tonight to start tidying up the rear arches and as alway had a quick look under to check nothing was a miss anyway long story short there is a leak in one of the fuel lines at the rear end before it goes behind the suspension bar. I can see a connector up near where the gearbox meets the rear of the car but access looks very bad surely you don't have to drop the torsion bar to replace the fuel lines?? Also are they expensive (silly question) and can they be fabricated like brake lines?? Any other help appreciated!
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 04-12-2005, 01:24 PM
Cars & Coffee Killer
legion's Avatar
Better fix that...your car could end up like mine....
5 liters of VVT fury now
-Chris
Old 04-12-2005, 01:35 PM
strath44's Avatar
doh - what happened to yours?
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 04-12-2005, 01:41 PM
legion's Avatar
Kinda just a joke, but I think mine was caused by a bad fuel line in the engine compartment:
One Less 'S'
-Chris
Old 04-12-2005, 01:47 PM
strath44's Avatar
ouch, yeah would like to avoid that! suppose thats always going to be a prob when you start disturbing a 20 year old system def one for the garage!
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 04-12-2005, 01:51 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Sounds like one of the rubber lines failed.
Can you tell exactly where it is leaking from, and perhaps find the hole/loose fitting?
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 04-12-2005, 02:05 PM
strath44's Avatar
Are these long lines running from the engine area to the tank at the back rubber I didn't squeeze them thought they were metal, but its definitely cracked and theres a small leak on the other line at the end of the long straight under the floor pan.
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 04-12-2005, 03:19 PM
fuel
Strath, the fuel lines are expensive (over a couple of hundred at least if i remember) but i was quoted over 60 quid secondhand - the problem is apparently the suspension has to be dropped to fully replace which is time consuming and so expensive.My s2 cab has slightly rusted fuel lines at the rear which i had checked out last november - they turned out to be ok and were waxoyled to protect.The garage that checked mine out reckoned that they could however replace sections of pipe if need be.I've had this happen before on my 924 - in the same place - however i replaced the section (just at the rear of the floorpan) with hydraulic hose.It is very dangerous when they leak due to the closeness of the exhaust - my 924 emptied very, very quickly at a set of lights and left me stranded - stroke of luck it never ignited!A common problem with these motors, i've also had brake pipes rust through as well.
1989 guardsred 944s2 cabriolet,
1983 metallic claret 924 lux (sold)
Old 04-12-2005, 03:51 PM
SoCal Driver's Avatar
Pipes? tubing maybe.
Was working as a trailer frame welder in my late teens. Good money but it was a graveyard shift. One of the foremen decided he was going to weld a hitch on his car. Struck the gas tank making a small hole and set the gas on fire that was leaking out of it. He jumped in the car and was making circles in the storage yard honking and yelling for a fire extinguisher! A long trail of burning gasoline trailing behind trying to catch up with the car!
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-12-2005, 05:29 PM
strath44's Avatar
yeah the brake lines went a year back they were relatively straight forward to sort but this looks like a nightmare. 60 for used lines seems okay, would be great if the line can be replaced in sections will try and find out. Can anyone confirm if the suspension has to be dropped on my car to do this if so 2what should I think about replacing at the same time? cheers
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 04-12-2005, 11:55 PM
strath44's Avatar
Hey (44cabby) can anyone give me any info on replacing the lines with high pressure tubing how did you do it on your 924. Will a good garage know about this sort of thing or will it need to go to a specialist?? Has anyone replaced the main fuel lines can the metal ones be replaced with rubber high press to avoid dropping the t-bar??
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 04-14-2005, 02:24 PM
john dory's Avatar
try porscheshop.co.uk, good online catalogue, good 'phone service, 0870 0055911. Company is in Kidderminster
Old 04-15-2005, 06:32 AM
I would prebend just the part necessary to get around the torque tube then bend the rest inplace. Use Parker-Hanifin swedge lock fittings to cinch to the tubing.
Old 04-15-2005, 06:55 AM
strath44's Avatar
thanks for the help gents getting somewhere now especially on bending it in place thanks Socal, also cheers for than porsche shop www. its a great site unfortunately the lines on it are still 195.
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 04-15-2005, 12:39 PM
lines
Strath, i used high-pressure tube from a local engineering firm and fitted it myself which was a pain in the arse as my pipes had corroded where the pipe goes over the suspension - very difficult to get to as i didn't have access to a ramp.The first pipe i used wasn't strong enough and burst very shortly after due to the high pressure in the system.I used jubillee clips to secure the hose which was ok but not ideal.The garage i'm using at the moment reckon that it is possible to replace sections of the pipe and if i have problems with my 944 i'll use this option rather than using the hose again.I think douglas valley breakers have decent used fuel lines for about 60 pounds though.
Old 04-15-2005, 05:56 PM
strath44's Avatar
thanks will get on to DV today!
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 04-16-2005, 12:09 AM
