Rear Clanking is BACK--- UPDATE!!!!
The Clanking is Back!!! I thought i fixed it...well I did for 6 months or so now its back. I just lubed the rear end before, I'll do the same but what am I looking for. The clank ONLY appears when Im in gear and accellerating. Clues, info appreciated...Thanks in Advance...
88 928 S4 Black, Black and Grey Interior
Alpine head unit & amp, Bazooka Tube, Viper 5704 Smart Start GPS tracking, Devek Headers, Flowmaster 40 3" with Resonator, Auto Authority chips. Custom Luggage Cover.
Traded - 86 944 Turbo Guards Red. RIP - 85.5 944 Guards Red
Old 04-12-2005, 01:42 PM
lousailor's Avatar
Send a message via AIM to lousailor Send a message via Yahoo to lousailor
Hmmm,
I had something similar, but it was more of a rubbing noise. I raised the car and looked for something loose, and moved the axles a little, but couldn't find anything. It went away for a while, but came back worse. Other posts I've read say that a metalic noise that is directly tied to acceleration and car speed (vice engine speed) sounds like CV joints. I ordered new ones, and removed and took apart the old ones (originals I think). There was some significant wear and damage in the joints so I'm hoping that was it. While I was at it, I stripped and repainted the axles (better than new), got the boots on and the CV joints are next. Pics show old axle and stripped, then painted and new boots (joints are in the boxes).
Louie
'85 (Early) 944 - Beater
'87 924S - Crunch/Rebuild
'76 924 - Long Gone
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Old 04-13-2005, 07:57 PM
lousailor's Avatar
Here's the new axles all put together, just need to pack the moly grease on each joint and bolt in place. I'll let you know if it fixes the noise.
Louie
'76 924 - Long Gone
- Mario Andretti
Old 04-14-2005, 12:16 PM
I had the same exact problem. First I thought CV joints even ordered a set . But to find out it was my center cap
88 924s
Old 04-14-2005, 12:35 PM
CENTERCAP!!!!!! Man I was thinking the excat same thing yesterday and I couldnt get it off. Wouldnt you know it the ****in noise is gone.
Old 04-14-2005, 03:17 PM
SoCal Driver's Avatar
Louie, Really great looking axles! Now you have to take off the CV's and grease the heck out of them. Yes both from both sides with the gray moly grease.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-14-2005, 03:30 PM
Did you get the memo?
onewhippedpuppy's Avatar
Wow Louie, so clean! I just did mine, I swear everything within ten feet of me had grease on it when I was done. You did it the smart way, all new stuff. I tore apart each CV, cleaned and inspected them. Everything looked good so I reassembled, relubed, and then put them on with new boots. Amazing the difference it made.
Matt J.
'09 RX-8 R3
Old 04-14-2005, 03:46 PM
lousailor's Avatar
Whooo, putting them in was easier than taking them out. So far so good. No noises and smooth driving. I'll get it back up in the air in a week to check the bolt torques. At this rate I'll have a new car in a year.
Louie
'76 924 - Long Gone
- Mario Andretti
Old 04-19-2005, 06:07 PM
Send a message via AIM to ShApE
ok guys i got the same exact problem, what center cap? im sooooo sick of this noise.
Old 04-19-2005, 10:16 PM
well i took the cap of noise is still there
Old 04-20-2005, 08:45 AM
I took my car to a local shop next to my business and carefully watched as they took things apart. The boot was almost completly dry. So I had them repack both axels. There was also some play in the right rear emergency cable. Im thinking thats the culprit. Is it possible the extra slack in the cable was allowing the excess cable to get caught in the wheel when driving. I dunno but for the moment everything seems to be OK. The innards of the CV seemed fine the bearings as well. Hopefully thats that.
Old 04-21-2005, 03:27 PM
