livewirevoodoo's Avatar
Fog Lights - won't turn off
Fog lights won't turn off. With key in the accessory position (and started, ect..) , fog lights stay on. Happens with headlights in any position, and running lights on and off. The fog light *switch* light goes on and off when pressed, but the fogs stay on. Busted relay? What gives?
Thanks.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 04-12-2005, 04:54 PM
SoCal Driver's Avatar
Relay.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-12-2005, 05:32 PM
seaboltman's Avatar
probably a short of some sort, time to follow some wires?
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 04-12-2005, 05:33 PM
I suppose the relay could be welded shut, especially if you have been running 100 watt bulbs in the fogs. Pull it out and test it. Then move upstream and start testing the switches.
Old 04-12-2005, 05:35 PM
