max29a's Avatar
engine power loss/stuttering
Well I am going to pull the ignition switch out and look at it today after work, but I am recently doubtful that that is the problem.
Coming in to work today I dropped the girlfriend off at school first so I had about a 45 minute drive total, and the further along I got the worse the problem got. At the end I was noticing that if I pop the hood and let the engine bay cool off for 5 minutes I could drive for maybe 1-3 minutes, if I let the engine bay cool off for 10 minutes I could drive for 5 minutes, etc...
So it seems like something in the engine bay being too hot is the culprit.
Again, when it dies it just cuts out and the DME relay always clicks once when it goes out and once when it comes back. And sometimes clicks wildly while its out. I still have full electrical power inside.
Could this have somethign do with ignition coil or cap and rotor? overheating? they have all been replaced recently but how would I check them?
1985.5 944 NA - 270k miles!
2001 suzuki sv650 - 37k miles
oil change done at 270k
timing belt done at 240k
Old 04-14-2005, 09:41 AM
fast924S's Avatar
Send a message via AIM to fast924S
Have you checked your ignition coil???
Sorry, Didnt read you full post before I posted
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 04-14-2005, 01:48 PM
