Driver
Front brake rotor help
Hi all,
Removed my calipers and the countersunk screws that hold the rotor onto the hub. Rotor still wouldn't budge. Had to remove the bearing and slide the whole assembly (lugs and all) off of the axle.
I have also removed the lugs from the inner hub.
Am I missing anything to seperate the rotor from the innner hub?
Thanks in advance,
GHEN
'87 944
Old 04-18-2005, 12:09 PM
fast924S's Avatar
Send a message via AIM to fast924S
HMMm I dont remember there being any screws just bolts from the back side
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 04-18-2005, 01:54 PM
Later 944s use the 928 style of brake disc. If the screws are removed the disc should come off. If not needs pressing off and the hub thoroughly cleaning before refitting.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 04-18-2005, 03:02 PM
You can also use a 13 mm bolt (m8 x 1.25) in the threaded holes on the rotors to act as a puller to remove the rotor from the hub.
gb
Good luck, George Beuselinck
Old 04-18-2005, 03:34 PM
Driver
Thanks BritWrench, it seems like they are frozen together quite tightly.
GHEN
'87 944
Driver
Well an hydraulic brake press and 15,000 PSI later and they are out!
Thanks for the help.
GHEN
'87 944
Old 04-23-2005, 07:59 AM
