Parrothead member
VINMAN's Avatar
Question Rear seat removal
Ok, how does the #!*%@#! rear seat come out???
Vinny
Old 04-25-2005, 05:07 AM
Cars & Coffee Killer
legion's Avatar
First you remove the rear seat belts, then unbolt and remove the upper section of the rear seat. The lower section has a series of brass clips running along the bottom. Take those out. Then you will find that it is glued to the frame. I did mine on a hot day and the glue had mostly deteriorated. You might need to use a heat gun and slowly work it loose in your case.
5 liters of VVT fury now
-Chris
Old 04-25-2005, 05:34 AM
Parrothead member
VINMAN's Avatar
Thanks Legion! I had a feeling it was glued or something . i was getting nervous yankin on the seat i thought it was gonna rip. I'll try the heat gun tonite.
Vinny
Old 04-25-2005, 07:39 AM
legion's Avatar
Like I said, I didn't have to use a heat gun. If it was better attached, I would have expected it to rip the seat foam when I pulled. I'd watch very carfully to make sure the heat gun does not melt the foam either.
-Chris
Old 04-25-2005, 08:15 AM
Parrothead member
VINMAN's Avatar
My seats on there pretty solid. hopefully i wont damage it.
Vinny
Old 04-25-2005, 08:20 AM
