thierry75's Avatar
hatch lock cylinder seal
Hey guys! I'm trying to change the seal around the hatch lock cylinder - i remember seeing an assembly drawing or a diagram somewhere (I thought it was my Haynes book but it's not)-also tried Clark's garage but nothing there either - does anyone know how to take the lock out? or where I could find a drawing? -thanks
924S
1987 Black/black
5 speed
74.5K miles
http://www.p-caronline.com/directory/sexborg75
'boredom is a sin, boredom is unholy'
Old 05-01-2005, 06:45 PM
livewirevoodoo's Avatar
pretty simple... there are a 4 nuts that need to be taken off, and the assembly slides out the hole from the inside.
additionally, there are 2 pins which attach the lock to the hatch release assembly. I believe they use use little plastic clips to secure them into the lock mechanism. all said and done, it takes about 15 minutes to do.
edit:
if you have a copy of the PET, it will show an exploded diagram of the assembly, but once you take a look at it beneath the carpeting, it is straight forward.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 05-01-2005, 07:02 PM
thierry75's Avatar
thanks dude...what's the PET?
924S
1987 Black/black
5 speed
74.5K miles
Old 05-01-2005, 07:30 PM
not sure what the letters stand for (although somethng tells me P = Porsche).
Its the electronic parts catalouge program. Pick a model, year, car system, and it shows an exploded view of all parts. Click a part, and you get the part #. Convenient for things Pelican carries but doesnt list on their pages. Also gives you a general idea of how things fit together.
''87 944na 85k
Old 05-01-2005, 08:08 PM
bertman's Avatar
IIRC... If you're just replacing the rubber seal around the lock there's no need to remove the lock. Simply remove the old rubber and press in the new one.
bertman
84 944 Original Owner
65 Plymouth Satellite
08 Mercedes-Benz E 350 Sport
Old 05-01-2005, 08:59 PM
bearone2's Avatar
$3 or so thru the dealer, just did it.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 05-02-2005, 11:13 AM
