Valve Spring Tension/Compression Spec
I requested a valve spring compression check for my engine head overhaul, but they don't have any reference to the spring specifications. Does anyone have reference to this spec?
Much appreciated, Scott 1984 944 na |
No specification is given for spring compression. The only specification that is given is installed spring height. 41mm for the intake and 40mm for the exhaust.
AFJuvat |
| All times are GMT -8. The time now is 01:47 AM. |
