-   -   Re-installing lugs (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/220460-re-installing-lugs.html)
GHEN 05-08-2005 02:08 PM
Re-installing lugs
Hi everyone,
I removed the lugs from my front hubs before sending the hubs out to be plastic-bead blasted.
I have the hubs back and need to get the lugs back in (they improve the ride a great deal!)
I have gotten two of the lugs back in using a hammer, but I have caused two or three very slight dings in the hubs.
I believe it is only a matter of time before I whack something really hard.
Is there an easier method for this and/or is this something a mechanic can do for me easily?
Thanks,
GHEN
scheistermeiste 05-08-2005 04:07 PM
do you mean the studs the lugs go on? if so just take them to a shop with a press and have them pressed in... or go to harbor freight and but a press, press them in and then return it and say it didnt work for what you wanted it to do.
944 Ecology 05-08-2005 06:00 PM
Or, get yourself a large vise and a deep 1 inch socket. Put the socket over the threads and use the vise to press the stud into the hub.
gb
