Oil WIERDNESS!!
I just changed my 924s's oil and noticed a fuel odor comming from the spent oil. My oil light also comes on erratically- sometimes flashing and sometimes steadily, and sometimes not at all. Iv'e thought about the oil pressure sending unit, but the pressure gauge acts normally, idling at 3 or so, and at 4-5 or so when under load. But of course that still wouldnt explain the contamination. In any case im not driving her untill this is fixed because I understand this could cause serious engine bearing damage. Thanks much for your help
![]() Last edited by blk924s; 05-10-2005 at 09:13 AM.. |
winter-hater club member
sounds like fuel blow by in the cylinders. have you done a compression/leak down check? could also be that the crank case is not venting properly. may be other problems as well.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Stuck injector. Need to pull the fuel rail and pressurize the system to see if one is leaking. Don't let this go. You can quickly ruin your engine.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
No, i havn't done a compression/leakdown test- ill look in to that as well as the injectors, but im not clear on how the crank case vents and what would block that from happening?
