livewirevoodoo's Avatar
Rim/Wheel Question
Will OEM Boxster rims (16 inch) fit an '87 944?
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 05-10-2005, 05:00 PM
Non Compos Mentis
Yup.
Old 05-10-2005, 05:26 PM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
Actually, I dont belive they do. The laste offset cars 87 ,88 have a clearence issue with the dustcap. The two sets that have this problem are Boxster and 964 16X6" fronts. The rears are fine. There are ways to make it work like spacers, but I sold the set I had because I diddnt like the way they fit, but go ahead and try it if you want because I may be wrong. I didnt try th boxster rims but they seemed the same as the 911 ones that I had.
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 05-10-2005, 08:34 PM
Am looking at some on ebay for $500.. They are 16-x-something. Also looking at some 18" turbo twists for around the same price, tho I don't believe N/As came with 18" as a stock option, right? Would like to not have to beef up the rest of the suspension to compensate at this time..
''87 944na 85k
Old 05-11-2005, 03:49 AM
Z-man's Avatar
You can grind down the hub dust caps in order to have clearance for the Boxster wheels.
That said, IIRC, the stock wheels on 944's were at least 7 inches wide. (In my case: the fronts are 7Jx16, and the rears are 8J x 16). The Boxster fronts are 6J x 16, which means you'd have to go with a skinnier front tire, which in turn will only amplify the understeer our cars already exhibit.
My $0.42,
-Z-man.
1989 944S2 - June, 2001 - January, 2014
Visit my homepage!
Old 05-11-2005, 06:13 AM
bearone2's Avatar
Cool
mine are boxter "s" 17's with about 5/16th spacers on the fronts.
7 1/2 fr, 9 rear.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 05-11-2005, 08:39 AM
TCMdocs944's Avatar
Here is grinding for the early....works the same for the late
Try this
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 05-11-2005, 12:44 PM
Wow, that's a lot of work to get a set of Boxster wheels to fit. You really just need to grind the dustcap on the back side so that it fits. Some people have had the cap bottom out on the hub bearing cap. In that case, take the bearing cap off the car, heat up the center 2" circle 'til it's dark cherry red, smack it down 1/8" of an inch with a mallet and that's it! Wait 'til it cools before picking it up and re-installing. Hub cap should fit fine after that...
Old 05-14-2005, 06:39 PM
TCMdocs944's Avatar
Seems like alot of work Danno but it had to be done for cosmetic reasons.
I moved the stock 3/4 inch spacer from the back to the front for looks only.
This was on an 83. The wheels fit with just the dustcap trim but didn't "look" right. Now they are perfect.
Best thing is that when I go to get new tires I will probably just get them on a set of used Boxster wheels like before...cheaper than new rubber. Work is done, now i can just enjoy it.
Old 05-17-2005, 11:29 AM
