pokey's Avatar
Send a message via AIM to pokey
It runs, finally!
The 924S is on the road! Now I need a few items for it...
1) working window switches
2) decent seats, leather would be nice
3) oem socks
4) dash pad without cracks would be nice
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 05-11-2005, 11:41 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson Send a message via AIM to bryanthompson Send a message via Yahoo to bryanthompson
woohoo! good work!
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 05-11-2005, 12:30 PM
Banned
procon's Avatar
Send a message via Yahoo to procon
Re: It runs, finally!
3) oem socks
What color?
Old 05-11-2005, 02:11 PM
SoCal Driver's Avatar
If none of the window switches work replace the relay.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-11-2005, 05:10 PM
Non Compos Mentis
Oem socks! Dang! Thats what I've been missing! What's the part number for a pair? My feet are size 12.
Old 05-11-2005, 05:31 PM
pokey's Avatar
Re: Re: It runs, finally!
Originally posted by procon
What color?
What color do you have? Which parts?
1956 Ford F250
1955 BMW R69
Old 05-11-2005, 10:17 PM
pokey's Avatar
The relay is fine. I got 2 of the switches working (the only one that is still inoperable is the passenger remote switch on the drivers door, I think it's a wiring issue), they needed their contacts cleaned.
I am having an issue with my elec. mirrors not working, any ideas?
1956 Ford F250
1955 BMW R69
Old 05-11-2005, 10:21 PM
Not certain if the 924S uses the newer mirror drives or the early. The early are a PITA. The later ones are a much better design but have a tendency to break a 25 cent drive link. You have to buy a $300 drive to replace it. Well not really. The later mirrors drive is used in other cars too. Seen it in a later Ford Mustang.
As to the early drives; I've had to move them back and forth by hand a bit to loosen them. Also check the switch in the console. This too has a tendency to crorrode the contacts.
Old 05-11-2005, 10:27 PM
pokey's Avatar
Thanks SoCal. It was the console switch, dirty contacts again.
1956 Ford F250
1955 BMW R69
Old 05-12-2005, 06:48 PM
pokey's Avatar
I just finished doing the 3/8" bolt brass tubing shifter fix, I added a couple of nylon washers to keep everything moving freely. I also cut off 1 1/2" of the shift lever to lower the sift knob and shorten the throw. Makes a huge difference in driving comfort. It also makes getting to the radio controls easier.
1956 Ford F250
1955 BMW R69
Old 05-13-2005, 01:57 PM
I'd shorten mine but the syncros are bad enough as it is. Those nylon washers will wear out quickly. Get a conical or wavy thin washer and some heavier flat washers. put the spring washer between the shifter arm and one of the flats on the inside and just one of the flats on the outside.
Where did you get the brass bolt from?
Old 05-13-2005, 02:01 PM
pokey's Avatar
No brass bolt. There should have been a comma between "bolt" and "brass tubing." The bolt is stainless. Just stuff I had laying around from working on boats. I do get bronze bolts from time to time, at GSA hardware on PCH in West Long Beach.
1956 Ford F250
1955 BMW R69
Old 05-13-2005, 02:14 PM
Did you tap the arm or use double jam nuts?
Old 05-13-2005, 03:09 PM
pokey's Avatar
I went with the double jam nut method. I'm going to replace the nylon washers with brass backed up with stainless washers.
1956 Ford F250
1955 BMW R69
Old 05-13-2005, 04:23 PM
Trust me. Get a spring washer.
Old 05-13-2005, 05:13 PM
pokey's Avatar
Will do. Thanks for the help.
1956 Ford F250
1955 BMW R69
Old 05-13-2005, 07:56 PM
