72 R Tribute
help electrical demons
my ac was hanging on by the adjusting rod(p/o) so i replace it so i tried to charge it and when i turned it on the engine fell on its face and died. i jumped it off because it was like the battery was completely drained in a matter of seconds and it was fine until the cooling fans come on. i jumped it again and i tried to turn on the headlights and it did the same thing. where should i start??????
Old 05-10-2005, 02:53 PM
72 R Tribute
sorry failed to mention it's an 83 944 na
Old 05-10-2005, 03:04 PM
It sounds like an alternator problem. Get the car running, if you can, and check the voltage at the battery. The voltage should read 13.6v or higher if you are getting a charge. Also check to make sure all your grounds are good, and double check the alternator belt and the connections behind the alternator.
Make sure the battery terminals are clean, and the cables are connected tightly(won't twist if you try to twist them).
It really sounds like the alternator, and sense you just remounted the A/C compressor, make sure you the wires are in good condition behind the alternator.
Jack
86 Porsche 951 - LR 3" Exhaust, MaxHP chips and ProfecB @ 15psi
83 Porsche 944 - Still under re-construction.
08 Suzuki Boulevard M109R LE
02 Nissan Altima SE3.5
Old 05-10-2005, 03:48 PM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
Cindy, you have a PM.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 05-10-2005, 04:01 PM
fast924S's Avatar
Send a message via AIM to fast924S
I agree Im almost 99% sure the alt. is not putting out a good charge
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 05-10-2005, 04:13 PM
72 R Tribute
thanks for all the info. my husband thinks my car is not a real porsche so i have to get it running good so i can prove him wrong.
911 R
Old 05-11-2005, 05:26 PM
Cindy:
How close to Richmond are you? My older sister lives in Richmond, and she and I have been "wrenching" on cars since I was about 10 (over 40 years!).
Although she does not have a Porsche, I can get her up to speed enough to help.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 05-12-2005, 06:16 AM
