DP944's Avatar
Porsche Crest Will it be faster???
Hey quick question....I just had my timing belt, rollers, tensioners, water pump, slave cylinder, and clutch cylinder replaced...think my car will be any faster. Im pretty sure it will be because before it went in it was leaking coolant bad and it didnt seem like it had as much acceleration.
Old 05-16-2005, 05:54 PM
SoCal Driver's Avatar
Sounds like at least 10 maybe 20 HP's there. I know my new tires added at least 20 HP's.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-16-2005, 06:04 PM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
you're such a smartass, hugh
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 05-16-2005, 06:11 PM
Dan in Pasadena's Avatar
If you wanna go fast here's the secret ...........chrome valve covers, works every time.
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 05-16-2005, 06:29 PM
DP944's Avatar
Funny....I was being serious by the way...Ive heard if your engine tends to overheat it can rob power, in turn slower acceleration. Also if your engine isnt timed correctly it also can rob power. Ill put money down that my car is quicker.
"I couldn't find the sports car of my dreams, so I built it myself." Dr. Ferdinand Porsche
Old 05-16-2005, 06:44 PM
I was teasing, of course. Sure, any car that is in a less-than-maintained or poor state of tune will defginitely run better once it is brought up to its potential. But I'm not sure that qualifies as "faster". Get that car up to its stock potential and you have a solid, well engineered sports car.
Dan in Pasadena
Old 05-16-2005, 07:09 PM
fast924S's Avatar
Send a message via AIM to fast924S
I agree with DAN, It wont be any faster then stock, but it might be faster then what you had, Problem is when the engine gets really hot it might start to pull out some timming advance, thus affecting performance
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 05-16-2005, 07:31 PM
Faster? Faster than a honda odyssey mini van? Probably not. It's all in the handling and adequate power.
MW
Old 05-17-2005, 07:17 PM
livewirevoodoo's Avatar
most noticable difference for me was fuel filter, plugs, rotor and distributor... verify your wires are good, your fluids are fresh and you don't have any vaccuum leaks...
i wouldnt think a timing belt change would effect speed any, but will definitely prevent catastrophic valve damage. Dan in Pasadena - will this still happen with chromed valve covers? I heard somewheres that the chrome plating will take most of the damage leaving the valves untouched.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 05-17-2005, 07:49 PM
Depends if you polish the chrome with an argyle or athletic sock.
Old 05-18-2005, 07:57 AM
adrian jaye's Avatar
Re: Will it be faster???
clucth cylinder will def increase BHP, make the car nice and smooth and enhance the power bands
[ade walks away]
PYSCH!!! only jk
the car should be back to spec, especially if it wasnt running correctly, will you notice any differance, possibly.
take 2 placebos and call me in the morning..
[engine will be happier but !]
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 05-18-2005, 08:20 AM
