Send a message via AIM to drfatz
Flywheel Install Help!
So I just removed the old flywheel and am about to install a Fidanza flywheel...I noticed that the stock slywheel has three set screws out the outer perimeter (I presume these are sensor pickups) the Fidanza only has one...is this a problem? Do I need to drill holes in the Fidanza and install the other two screws????? I need help ASAP for the project is now on hold
1985.5 944 NA
-Racing Headers, Cat-less Borla exhaust, New racing Cam, Turbo valve springs, multi angle valve job, big bore throttle body, Eprom, blue printed injectors, throttle response cam,
-Just installed: M030 Suspension with turbo A-arms and hubs. Big Reds with rotors and stainless lines. Turbo sway bars front and rear. Boxter wheels, turbo mater cylinder, and MOMO steering wheel and shift knob.
Just Finished: Clutch, flywheel and transmission...and TONS more!
Old 07-07-2005, 04:57 PM
fast924S's Avatar
Send a message via AIM to fast924S
Do I search, I think this has been asked before, If I remeber correctly all you need is the one set screw but agian Im not sure so I would wait for other replies. Also make sure the screw is set at the right depth or your gonna smash your sensors!!!
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 07-07-2005, 06:09 PM
SoCal Driver's Avatar
Just the one. The others are for the factory/dealer sensor that no one uses.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-07-2005, 07:56 PM
Thanks SoCal Driver....I figured that was the case, however I didn't want to install everything and then have the car not run because of two missing pickups. For then the entire process would have to be repeated :-P
1985.5 944 NA
Old 07-08-2005, 05:58 AM
ae1969's Avatar
Send a message via ICQ to ae1969
Yup........only one pin.......but ALSO Set the HEIGHT of the pin.............. The pin does not come set from Fidanza.
THe circumference of the 2 flywheels are different so dont go by the height of the pin.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 07-08-2005, 08:16 AM
Wow apprecaite the good advice..you guys saved me alot of trouble in the near future
1985.5 944 NA
Old 07-08-2005, 08:21 AM
