Intermit..A/C....Little help please
Hey Guys,
Florida is really starting to suck without ac. 1. Went "out" last year a month after my stereo instal 2. Is doesn't cycle on and off like low freon 3. If it decides to work it is ice cold, cycling as normal but within about 15 minutes no more cool. 4. later it may decide to come on again an work perfectly... 5. Blower works fine, radiator fan comes on fine :( What would you check first? A/c knob and temp bezle? A/c temp sensor at condensor? ?? ?? I almost wish it was just a compressor....At least I would know what to change. HelpSmileWavy |
Anti-icing switch, drivers side footwell, next to the magic "Oh my god why am I getting nothing but heat out of my vents!!??" clip
There are a couple of screws on the switch to remove\adjust it. Detailed in workshop manual, AC troubleshooting section Rotsa Ruck! AFJuvat |
You da best Man!
I shall look for said switch using the force if necessary... make much adjustment or smote it I shall. (i bet it is just a loose connection) |
| All times are GMT -8. The time now is 12:50 AM. |
