rear wheel bearing
I have an 89 944. It has an inner and outer rear wheel bearing on it. When i tried to order the seal i was told that an 89 has only one rear bearing on each side. Can anyone shed some light on this?
89 944 na Dove Blue Metalic 2000 chevy silverado 2000 chevy 454 dually black 79 GMC short bed 4x4 4 quarter horses 89 acura legend GS sedan |
You should have the alumimum arms where there are two ball bearings in a single outside race but seperate inside races. It's considered a single bearing unit and has to be replaced as one.
The self locking axle nut should be replace and torqued to at least 350 ft lbs.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Thanks for the info. So I reckon I gotta drive the outer race out?Yeah that bearing nut was on purdy tight. I weight bout 230 and had a 2 ft. cheater bar I was jumpin on.
No, you drive the the hub out first. The you will need a hub pulling tool to pull the bearing out and press it back in. The trailing arm doesn't need to come off and it can be done in the car. Makes life easier to warm the trailing arm with a hot-air gun and put the bearing in the freezer. If the hub is worn where the bearing fits on it...will need replacing and they are expensive.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
I guess I should ask which end the 924S has aluminum arms on. Front or back. If the back arms are steel then the process is a bit different. Take look.
All 924S have alu rear arms
Steel in front then. OK. Senior moment has passed.
Thanks guys. I've only been a Porsche driver for about a year. It sure is nice to have a place to go for information as the porsche factory manual is so expensive and kind of elusive. The Hayse manual leave a little to be desired. Once again thanks
Don't forget to replace the locking nut like SoCal said.
Lawrence 1986 951 2002 SLK32 AMG 1987 328GTS 2011 528i |
