sbloxxy's Avatar
944 alarm
Can any one help with this one? Just bought a 1990 S2 and according to the option label on the inside of the rear panel, it says it has a factory fitted alarm. Unfortunately, the owners handbook I have is from a 1986 model and it says to operate the alarm, you need to use the extra lock near the drivers side door lock on the rear wing. Well I haven't got one of those! How on earth does my alarm work and does anyone know what will set it off?
Jaguar X Type (fast)
'83 944 (faster)
'90 944 S2 - chipped, big exhaust, free flow air cleaner (Wow!)
Old 05-29-2005, 02:18 AM
Driver
Check & see if there is a keyhole in the driver's door jamb.
Good luck,
GHEN
'87 944
Old 05-29-2005, 07:20 AM
90 models use the key in the lock on the outer door handle to activate. It's combined with the central locking system. There will be a flashing light in the lock push button that goes on when you lock the car.
Get the right book for the car.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 05-29-2005, 10:36 PM
sbloxxy's Avatar
Definetly no lock in the door jam. Activating it with the key makes sense - only problem is that someone has changed the door lock buttons so I've got no flashing light. As you say, I need to get the right manual.
'83 944 (faster)
Old 05-30-2005, 03:48 AM
