-   -   Source for Piston Set (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/224203-source-piston-set.html)
3sonfather 05-31-2005 06:44 PM
Engine tear down reveals seized piston rings - anyone got a source on a set of used, serviceable pistons, or new (piston, pin, ring set combo). Checked classifieds - no luck.
Thanks for any info,
Scott
1984 944 na
Zero10 05-31-2005 08:22 PM
99% sure you'll end up boring out, and using over-sized pistons. If the rings have siezed, you've done some cylinder damage.
As for that, I got mine from a user named Ski over on rennlist. Pretty reasonably priced.
IceShark 06-01-2005 09:35 AM
A Rennlist member, Hussam Jamil from the United Arab Emirates, has a local mechanic that has many original new pistons for our cars and he is selling them for cheap, like $600 for a set of 4. Apparently the guy set up shop in the UAE about 4 years ago and brought all these parts. He hasn't moved many of the pistons so that is why he will let them go for $600.
So contact Hussam and see what he can set up for you.
3sonfather 06-01-2005 10:17 AM
Zero, the cylinders visually appear to be in great shape although my machinist will need to measure. IceShark, thanks I'll try to look up Hussam. The best I've found is PAP Auto for $200 each. I would have to seek another plan if the block is bad given the costs associated with oversized pistons, etc.
AznDrgn 06-01-2005 10:28 AM
I have a good set out of my '83 complete with forged rods that I'll sell you.
AznDrgn 06-01-2005 10:29 AM
Pistons are in NOVA too so I can probably save you time on shipping them.
IceShark 06-01-2005 11:50 AM
See what you need on oversize as Hussam mentioned there were some oversize in this stash.
Maybe AznDrgn can help you out but if you end up needing Hussam's e-mail address, I have it as I've sold some parts to him.
