-   -   engine bogs at 2,000rpm...what's prob? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/224816-engine-bogs-2-000rpm-whats-prob.html)
nosubstitute 06-04-2005 10:10 PM
My '86 944 Turbo is sick. A few days ago I noticed it was idling high (around 2-2,300) but ignored it. Then today it started bogging (almost stalling like it was starved for gas) at 2,000 rpm, would fall to 1,000 and idle. Playing with the throttle I could get several well timed blips to get momentum in engine speed to carry through the dead zone to 3,000 rpm when it would pick up and rev again. So it's not a gas problem I guess. But as soon as I eased off and the revs dropped under 3, it would 'die' and drop to 1,000. Obviously without the 2-3 range it won't drive, so I walked 5 miles home, grabbed the trailer and now have to do something. What's up? Is it the computer? If so, can I just replace chips, or do I need a new box? What else could it be? Any help would be appreciated...thanks.
earlr85944 07-02-2005 06:09 PM
Hi Greg please give me a call: its Rich from Long Island.
631-793-9943
fast924S 07-03-2005 12:16 AM
Check your vaccum lines, your tps and your reference sensors. Also when was the last time you did a tune up
carsonmx114 07-03-2005 08:06 AM
unplug your trottle position sensor and see if it runs better. it may not idle like this but if that is the problem the dead spot should go. my car did this and i barely made it home i think i payed around 60 dollars for a new tps and it cured the problem.
TSNAPCRACKLEPOP 07-03-2005 12:14 PM
bad ignition wires?
robm-951 07-05-2005 03:23 AM
What carsonmx114 said would be my first advise as well.
nosubstitute 07-06-2005 11:47 AM
It was a bad TPS sensor. A little difficult to get the inner screw out, but an easy and relatively cheap fix, thankfully. Thanks for all your help.
earlr85944 07-06-2005 03:56 PM
nosubstitute:
please give me a call or email me, you may have the wrong title for the car you picked up! please check it!
richsoler@hotmail.com
