shift linkage
I have a 1983 944 5-speed that has a lot of side to side play at the gear shift. It has this play even when the shifter is in gear. Thanks.
Old 06-20-2005, 02:04 PM
Non Compos Mentis
Your shift lever is worn. Easy fix. Last time I bought a new shift lever from the dealer it was less than twenty dollars.
You'll think you got a tranny rebuild when it's tight!
Old 06-20-2005, 02:13 PM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
If you replace the shifter and it's tight for a couple weeks, then loosens up again, you may have another problem.
I had the problem that the end on the shift rod going back to the tranny was warn out too. For that you have two options: 1. pay to have the rod replaced (~$800 because you have to drop the tranny) or 2. FRWilk's fix ( http://frwilk.com/early944/ and click on the "shifter repair link on the left side)
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Old 06-21-2005, 10:15 AM
Thanks for the help about the shift linkage.
Old 06-21-2005, 10:41 AM
