earlr85944's Avatar
early car runs with late dme only?
This may have gotten lost in another post and am looking for some technical feedback; 83 944 automatics n\a runs for @ 5-30 secs and shuts off like you flipped a light switch(replaced dme relay). I installed a late model dme and afm and the car runs fine???? i took the orig dme and afm and installed it in another car and it runs fine???? put the orig back into the car with the running problem and it stalls??? Swapped back and forth a few times and the results are consistant. WHAT THE HECK IS GOING ON HERE!?
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 06-06-2005, 10:40 PM
pokey's Avatar
Send a message via AIM to pokey
Your car is possessed...
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 06-06-2005, 11:22 PM
Send a message via AIM to AznDrgn
Check the part number on the AFM, sounds like it might be a late one too. Did it ever run right with the early DME?
'91 Jeep Cherokee 4.0L HO - Daily driver
'83 Callaway 944 2.5L turbo - Soon to be daily driver
'83 Porsche 944 NA - sold
'78 Porsche 924 NA- RIP
'89 Porsche 944 S2 - Parted
Looking for a nice 944S for a daily driver.
Old 06-07-2005, 05:56 AM
earlr85944's Avatar
afm part number is correct and yes it did run right with the early dme. It seems like it started after I removed the dme to test a parts car motor. The motor did work well and the dme worked correctly. I first noticed the proble when after a few days I reinstalled the Dme into the orig car. (coincidence?)
83 944....bye bye
Old 06-07-2005, 07:53 AM
Open the early DME and check the solder connections where the harness connector is soldered to the PC boards.
Cold or fractured solder joints are a know issue with these DMEs.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 06-07-2005, 04:17 PM
Back from Beyond
Does the car have factory alarm or central locking? I've read somwhere these can make DMEs do strange things when they're toyed with. That said, I'd cuddle up with the TV, the DME and a soldering tool for an evening.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 06-08-2005, 11:33 PM
earlr85944's Avatar
no factory alarm but does have a chapman lock. dme runs well in another vehicle so i dont want to open it unless i have to.
83 944....bye bye
Old 06-09-2005, 07:08 AM
