what is this rubber hose?
there's a small, approximately a half inch diameter, rubber hose that comes out of the brake fluid resevoir and goes through the drivers side of the hood, and down to behind the front driver's wheel well where it just sticks out there..... what is this hose? can take pics if needed..
What??? Definitely pictures.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
sure - I'll go take 'em now..
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
I think you are confusing the blue hose that comes off the reservoir that connects to the master cyclinder ........... and then there is a hose that comes from that area across to the drivers side wheel well for gas fumes into a charcoal reservoir.
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
My bad - I obviously didn't look close enough. It actually doesn't come from the brake fluid resevoir... as you'll see from this pic (the white braided line going into the wall)..
first off - what is that? ![]() secondly, here is the rubber hose I was talking about - just behind the drivers side front tire...
Braided (cloth covered) hose is the vent to the charcoal canister that you show in your last picture. Part of the emmissions control system.
AKA J BERK on Rennlist
If that last pic is of the bottom of the charcoal canister...the hose is a vent hose for the canister I believe.
Joe Current: 2014 Cayenne S Gone but missed: 2003 996 C4S; 1991 944 S2; 1984 944 NA |
