Send a message via AIM to ike229
Air Conditioning Lowers RPM
Hey everyone,
Now that its getting hot down here in florida I am trying to figure out why my A/C is robbing my engine RPM's. When i bought the car, the engine would componsate more power to the engine when the A/C was engaged... however this is not the case anymore. I have installed Wilks powerprom 2... could this be the issue?
'05 M3 - Alpine White
'88 924S - Black
'91 318IS - Alpine White
'88 Honda Hawk
'75 Honda CB360
Old 04-21-2005, 08:38 PM
The chips shouldn't be the problem. Sounds like you've got a bad idle-stabilizer valve...
Old 04-22-2005, 01:16 AM
Send a message via AIM to bluebullet
yeah the stablizer valve is no good. It should open up when the AC comes on to keep it from stalling..lets more air into the motor.
Also, it could be whatever sends the signal to the IAS to open up is bad. I dont know if the AC Pressure switch does that or something.
1985 944 / 2007 335i / 1987 325is / 1985 535i / 1999 528iT / 2006 X5
Old 04-22-2005, 06:53 AM
UPDATE
Well, i decided to try adjusting the idle today.... after reading that you should jump pin B, to pin C on the diagnostic port, to disable the Idle stabalizer valve. As i was doing this i noticed a vacuum hose that was disconnected... so i reconnected it. I then found another vacuum hose that had become disconnected, and reconnected that as well. The car seems to be fine now. Here are pics of what i reconnected.
.... this hose leads to this (correct me if i am wrong) .........
I had to reattach the line that has that red piece near the end.
'88 924S - Black
'88 Honda Hawk
'75 Honda CB360
Old 05-31-2005, 03:13 PM
Send a message via Yahoo to bigyagi
jesus, i could never sell aftermarket parts for these older cars. its like painting a bullseye on your backside!
1984 944 na.
FR. WILK power prom/dual chip.
2005 buick. daily beater
2002 grand am--better halfs ride.
olds 98 royal brougham--gone, but not forgotten.
Old 06-01-2005, 02:28 PM
Just noticed something while driving tonight. The A/C dial (not the knob that adjusts the fan speed) activates a relay which i can hear. If i turn the knob fully counter clockwise... the car idles just fine, however if i turn it fully clockwise the engine is still bogged down.
Update...
I found this relay in the passenger side footwell. It seems when this relay is activated that my car idles just fine, however it isnt always activated. I tested the relay and it seems to be fine. Does anyone know what causes it to activate?
'88 924S - Black
'88 Honda Hawk
'75 Honda CB360
Old 06-10-2005, 10:08 PM
