another "what is this picture showing" thread by ME!
Alright... decided to pull up the carpet in the trunk to fix some of the back lights... when I yanked it, I noticed two rubber hoses coming from the gas tank filler area... one goes out the bottom of the car and hangs underneath (hose 1)... the other just sits in the back right cubby (hose 2)... could this be the cause of my gas smell in the car?
http://forums.pelicanparts.com/uploa...1118781950.jpg while I had the carped lifted... found this.... what is it? http://forums.pelicanparts.com/uploa...1118782011.jpg |
Hose #1 Is the sunroof drain tube. Not sure about #2.
Picture #2 Is your fuel tank level sending unit. I had a gas smell in mine, and replaced the gasket on sthe sending unit. The gas smell went away. |
Hmm thats interesting hose 2 is missing on mine wonder if thats why I had water in the drivers sill?
I was told the item under the cover in the 2nd picture was a flux capacitor? |
i think #2 is the drain for the fuel cap area.
#2 should be pushed through the little hole you see in the bottom of the cubby.
Yeah, if that black circle thingy is not covering that hole, you will smell gas. I would use some sticky stuff to put it back on - not permanent stuff...
that black circle thingy is a grommet.
I know - mine fits snug... i just removed it for sake of the pic.
| All times are GMT -8. The time now is 04:04 PM. |
