Send a message via AIM to jakemu24
awful squeeking sound
After extended driving of my car I start to hear a wierd squeek from the front of the car. This only happens when the engine gets hot. It sounds like the noise is comming from the pullies infront of the timing belt cover. Do I need to oil something of get new pullies?
1985.5 Stone Grey 944-SOLD
1987 Yellow 951- For Sale
Old 06-15-2005, 07:26 AM
On my third belt change, the mechanic put in several new rollers. It made a huge difference in the car sonic-ally and performance wise.
AJF
1998 Glacier White Boxster
1971 Fiat 124 Spyder
1999 Mercury Mountaineer
Old 06-15-2005, 07:32 AM
SoCal Driver's Avatar
When was the last time the timing and balance belts were changed? 30,000 or two years is a good interval. This is when pullies are inspected and replaced.
Could also be the power steering and/or AC belts and pullies.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-15-2005, 07:38 AM
The timing belt only has about 8000 miles on it. But the problem isn't the timing belt. Its all the pullies infront of it like the belt that connects the power steering.
Old 06-15-2005, 09:38 AM
"I have a noise at the front of my engine" is a very nebulous statement. Expect a wide range of answers.
As I said in my second statement: Power steering and/or AC.
Old 06-15-2005, 10:08 AM
So your guess is that the bearing in one of the pullies is bad?
Old 06-15-2005, 12:22 PM
What do the front external belts drive? Power steering, alternator and AC compressor.
All three have bearings. Power steering is most commonly a problem followed by the alternator then the AC compressor clutch.
Take the PS belt off and see if the noise stops. If not then it's the alternator/AC.
Old 06-15-2005, 03:13 PM
thanks for the help
Old 06-16-2005, 07:04 AM
if the power steering is bad, can i just take off the belt and drive the car without power steering? Would any problems come up?
Old 06-17-2005, 08:40 AM
It's been done before. Not advisable to leave the belt off for any length of time. Testing is ok.
Old 06-17-2005, 08:01 PM
