more a/c help pls
ok so my a/c saga continues
today i started the car, a/c clutch was disengaged so ok press the a/c button, a/c clicks on, nice and cold, let it run for a few min, press a./c button a/c clicks off all great so then i take a drive and run the a/c for about 15-20 min press the button to turn it off, but it just keeps on cooling clutch wont disengage. i drive home and let it sit for a couple hours and it will work again and got thru this routine again.... could the cluth be freezing after running it awhile? thks again dub |
Make sure they set the air gap between the clutch plate and the pulley properly.
0.5mm - 0.65.. AFJuvat |
| All times are GMT -8. The time now is 09:06 AM. |
