Banned
procon's Avatar
Send a message via Yahoo to procon
So, what's a bad front wheel bearing sound like?
I replaced my alternator a few days ago & noticed a metallic kind of squeak upon driving.
It's not constant, often occurs when turning, but mostly on left turns & at low speeds(5 mph).
Wheel bearing taking a dump?
Anyone have a similar problem or have a suggestion?
Thanks in advance!
Old 07-01-2005, 08:20 PM
SoCal Driver's Avatar
Front disc brakes. Could be from a bad/loose wheel bearing.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-01-2005, 10:41 PM
Custom User Title
Dave L's Avatar
if its primarily when you are turning it is probably a wheel bearing. The sound will be a howling noise, it will get worse and louder. If its happening when you turn left it is probably the right bearing. Give the wheel a tug and see if you have any play.
Old 07-02-2005, 05:37 AM
Banned
procon's Avatar
Thanks guys!
Old 07-02-2005, 06:33 AM
