Question Resistance of ignition coil normal okay?
Hi,
According to Hayes my 924 ignition coil should have resistances of :
1 - 1.3 ohm between term. 1 and 15
5.5 - 8 kOhm btween term. 1 and 4
but is measured 3.3 Ohm and 8.6 kOhm...
is this still okay, because its some more then the 'allowed' range. should i replace it?
thx!
Old 07-04-2005, 12:10 AM
SoCal Driver's Avatar
Disconnect all the other wires and check it again.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-04-2005, 10:46 AM
I did measure with all wires lose, so there was nothing connected while measuring!!!
Old 07-04-2005, 10:52 AM
