Stripper
I was so happy to finally figure out how to remove the 6mm nuts from under the cam housing, you know, thru the little 8mm caps! I removed all the nuts but one, STRIPPED! My ? is, can I remove the whole head w/out getting off the cam housing? Maybe I'll drill out the bolt after the head is removed.
Frank in Naples, FL
1972 911T
1983 944
Old 12-12-2004, 07:40 PM
No, you have to remove the cam box before the head. You'll have to get the bolt out. I would try getting another size allen socket or a Torx socket and hammer it in. Usually that will enable bolt removal. When undoing these bolts only use professional class sockets. I like the Stahlwille or Hazet ones. If all else fails you will need to drill the head of the bolt off.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 12-12-2004, 08:59 PM
s928s's Avatar
If that is the last bolt out and it is stripped. I will be harder to get out because the tension of the valve springs are against the one bolt. I would put back in 2 bolts on the upper and 2 for the lower housing. Then wake up the stripped bolt by tapping it with a hammer and a punch. then take a torx. or slightly larger SAE or metric sockets and hammer it into the stripped bolt. If this does not work as "britwrench" noted you will have to drill the head off the bolt, 1/4" bit should wok. The head will not come off without the cam housing coming off.
autowerks9
PCA SINCE 1991, REISENTOTER
1982 EURO 928S 320HP MEDIORMETALIC/BURG.
1987 944S- GT3 BODY CONVErSION RED/BLACK( sold )
2003 MERCEDES E500 Sport "Einfarbig"
Old 12-13-2004, 04:25 AM
Don 944 LA's Avatar
Angry
Man, I thought this was another " Grid Girl " style thread ..
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 12-13-2004, 01:57 PM
Send a message via AIM to operationcougar
i hear its much easier to get to them if use a five dollar bill, instead of just singles
95 - BMW 740i (daily driver)
02 - kawasaki mean streak (nice weather driver)
RX-7 built of other RX's (and a good place to throw money) (sold)
z31 300zx vg30det+ (new money sucker)
Old 12-14-2004, 02:50 PM
armandodiaz's Avatar
Hold on before you start drilling! This was a very common problem when I was working on-the-line. Once you stripp the allen on there usually is no way to get it out by those means. This is how we did it:
1. As David said put the surrounding bolts back on.
2. Take a 12mm (maybe 13mm I can't remember it's been 15yrs) 12point socket with an extension. Use a cheap extension as it will be useless as an extension after your through.
3. Hammer the socket/extension on the outer perimitor of the bolt.
4. SLOWLY break it free.
5. Continue and replace ALL remaining bolts. If one stripped chances are the other will soon go.
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 12-15-2004, 07:52 AM
Thanks for all the advice. I got it, I replaced the two bolts next to the stripped one, to take off the tension and then I tapped in a reverse threaded bolt extractor. It almost came out too easily, if that's possible.
Frank in Naples, FL
1972 911T
1983 944
Old 08-07-2005, 05:01 PM
