Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
murn's Avatar
Question Problems tensioning the timing belt
Into the final stages of replacing a blown headgasket on my 86' 951. I'm following the procedure as outlined on Clark's Garage and the factory manual, but using the Krikit tool instead.
After I get 4-5 readings of ~37-38 lbs and I turn the cam sprocket back to TDC (from the 10 degree or 1-1/2 tooth counterclockwise position) I loose the tension on the belt. If I continue to rotate the sprocket 360 degrees clockwise back to TDC there are times when I recheck tension and it will be OK again, but it will also fluctuate from a low of ~20 lbs to 60-70 lbs.
My balance shaft belt is tensioned properly and does not fluctuate in tension like the cam belt as I rotate the cam 360 degrees.
any idea what I'm doing wrong?
1986 944T (for sale)
2003 Boxster S
Old 07-03-2005, 01:32 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Do a search in the 924/944/968 technical forum, user's name: Taz's Master, and key word: timing belt. I asked the same question (because I was in the same situation), and the Belts Again thread contains an answer that allowed me to properly tension my timing belt. (I think it was to do 2 complete revolutions, back up 1.5 teeth from TDC and tension the belt, but check the response).
You are using/reading the tool properly, but your procedure is wrong.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 07-03-2005, 06:00 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
ae1969's Avatar
Send a message via ICQ to ae1969
Yikes......... yup
Taz is correct.
2 revolutions and back 1.5 teeth.
Then you tension the belts......
Turn it a couple of more turns.......... and back 1.5
Check tension.
Do this as many times as you need to get comfortable with the readings you are getting....
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 07-03-2005, 07:18 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
murn's Avatar
yeah I was doing the correct procedure all evening. Just got your posts, and the tension held this time. Thanks.
I'm not out of the woods yet. The car cranked over and sounded like it always did (before the headgasket failure) but then died after running at about 1000 rpm for about 5-10 sec. I tried it another few times and it would crank and abrupetly stop without starting.
Any ideas?
2003 Boxster S
Old 07-03-2005, 08:02 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Send a message via AIM to yieldsign2
You never rotated the cam without it connected to the timing belt right?
1985.5 944 NA
Old 07-03-2005, 08:17 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
murn's Avatar
No the cam was never rotated while on the head. I had the cam seals replaced when I had the head serviced, so likely rotation there and when I was putting it back on in the TDC position.
I think you are suggesting that I might have rotated the crank without the belt attached. Answer is no.
Could the car be flooded? As I mentioned in a previous message to AE1969 my first attempt failed and there was a lot of noise and shut the car down. took off the belt covers to find no tension on the timing belt. There was a substantial amount of gas in cyclinder #1 (probably the same for the others) when I retensioned the belts properly this time.
2003 Boxster S
Old 07-04-2005, 04:52 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Check compression.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 07-04-2005, 06:22 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
AFJuvat's Avatar
Sounds like your timing slipped.
Roll the motor over by hand to TDC#1 look on the joint between the engine and the bell housing - you shoud see a notch in the flywheel. Additionally, the mark on the camshaft housing should line up perfectly. If they are not lined up, your timing is off.
If you are not lined up, you likely bent a valve. if you are lined up, do a compression check it (as previously stated)
Many times, especially if you are unaware of the possibility of it happening, the camshaft can roll slightly when you are installing the camshaft housing on the head, - not much, just a tooth or so. Couple this with the crankshaft not lined up exactly (I use the mark on the bottom of the flywheel) you can easily get 1 - 2 teeth off on your timing.
Fingers are firmly crossed for you.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 07-04-2005, 07:14 AM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
murn's Avatar
AFJ, I triple checked the position yesterday with the third method that was suggested by AE1969 (since I could not lift my car enough to see the flywheel, I need a new jack). I took out spark plug #1 and inserted a long dowel. The dowel continued to rise to the TDC mark on the cam sprocket and immediately fell after the mark was passed, I could also visually see the piston rise and fall as TDC was passed on the cam sprocket.
So I think I'm good there.
I will have to check compression when I get home later today. I've been told there is little value in cold compression numbers. I'm assuming that if I get some really low numbers I'm gonna be replacing some valves.
One followup question. The belts are tensioned fine now but while hand turning the crank there are positions when it turns very easily and some postions that require much more effort. Can anyone offer an explanation?
Crossing fingers too.
Thanks for all the advice so far, stay tuned.
2003 Boxster S
Old 07-04-2005, 08:45 AM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
winter-hater club member
nynor's Avatar
turning the crank will be hard when the motor is creating compression and then will be easy, even continue the rotoation, as the compression is released. did i understand your question correctly?
"COOL PRIUS!" - Nobody Ever
Old 07-04-2005, 08:52 AM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
ae1969's Avatar
My toes and fingers are crossed as well............
You are feeling the compression strokes. Even with the plugs removed you will have resistance.
If you are off 3+ teeth. The valves will hit......it will be obvious. AF is right ....... the timing more than likely slipped with the loose belt.
We are all hoping no major damage was done the first time.
Old 07-04-2005, 08:55 AM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
murn's Avatar
Taking just about any and all offers.
Black on black.
Polished Fuchs.
3" Lindsey exhaust.
Lindsey dual port wastegate
Guru Racing chip.
?# screwed valves.
Damn compression numbers were pathetic. I got it running ruffly with full throttle came off and it died.
guess the next step will be to strip it down and visually confirm which ones but it could be all of them. Looks like it will wait to next year. To add insult to injury the drivers side mirror feel out when I slammed the door. A sign that I should quit now.
thanks for the help.
2003 Boxster S
Old 07-04-2005, 06:14 PM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
AFJuvat's Avatar
Awwww hell.
What were the numbers?
Old 07-04-2005, 07:24 PM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
murn's Avatar
kinda weird actually
Cyc #1: over 300, 105, 90. Each took about 4-5 cranks to achieve. Each time gas ejected from the release valve on the gauge.
Cyc #2: 120 (10 cranks), 60 (7-8 cranks), 30 (7-8 cranks)
cyc #3: no reading
Cyc #4: no reading.
Not sure if I toasted the gauge after that first reading.
2003 Boxster S
Old 07-04-2005, 07:50 PM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
TSNAPCRACKLEPOP's Avatar
meowwwwww, dang!!!
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 07-06-2005, 06:01 AM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
ae1969's Avatar
Well..........I figure you bent 4 exhaust valves...........
I do have a spare head............
Take a deep breath murn............ and put the gun down.
It can always be worse.
...........but if not.......... I can always use another car.
Old 07-06-2005, 09:06 PM
  Pelican Parts Technical Article Directory    Reply With Quote #16 (permalink)
murn's Avatar
Will the entire head really be ruined? I thought the valves themselves can be replaced individually when this happens, and the head can usually be saved.
2003 Boxster S
Old 07-07-2005, 07:41 PM
  Pelican Parts Technical Article Directory    Reply With Quote #17 (permalink)
Hey, mate,
I'm in Wainwright - not too far from you. If you decide to get rid of the car, let me know because I may be interested in it.
Judging by your compression numbers, I'd guess you've bent some valves. It's really important to get the timing belt right. Head over to clark's garage (don't know the internet address off-hand, but a quick search should do it for you) and read everything he's got on his site about t-belts.
If you do decide to fix the car, keep in touch with me and let me know what you're up to. I've been doing my own belts for years and could help out if you need it.
HTH
S.
'84 944 - new-to-me DD!
'83 944 - looks like ass, runs like horse - in primer.
'82 931 - roadster project - forever incomplete.
'80 924 - spouse's yellowjacket.
Some wrecks and a 924 racer.
Old 07-17-2005, 07:59 PM
  Pelican Parts Technical Article Directory    Reply With Quote #18 (permalink)
murn's Avatar
Actually she fired up tonight but ran rough (not sure what the problem is now). I went to replace two dirty plugs and noticed that I mixed up my ignition wires. Also some smoking from the crossover pipes maybe (lose?) or the engine degresser (smells like Gunk), has me a little worried. The smoke was white and did not smell like glycol, wasn't blueish either. Hesitant to idle it again due to the rough idle and smoking.
If you wanna come check it out, anytime. I could probably post a picutre or two aswell.
I think I'll try another cold compression test first, think I blew the gauge the other time. We'll see.
2003 Boxster S
Old 07-17-2005, 08:38 PM
  Pelican Parts Technical Article Directory    Reply With Quote #19 (permalink)
Ran rough? Check timing again. You can run one tooth out on the cam (not the crank) and not trash your valves. Ask me how I know... But your compression test worries me (and the gang).
Smoking from crossover pipe? Burning off degreaser? Could be. The smell will tell you what it's burning. Is it smoking out the tailpipe? Black means too rich, white means coolant, blue is oil.
IF your t-belt is tensioned properly and you've turned the engine over by hand and not had valves strike the pistons, idling the car shouldn't hurt it. Then you can see if your smoke clears (so to speak!).
The most important thing is to be methodical. Don't chase ten things at once. Knock 'em off one at a time. I'd double check timing first, then belt tension, then look at compression. If your timing's out, a compression test won't tell you a thing, and so on.
Good luck and keep us posted!
BTW - are you military posted to Cold Lake?
Old 07-17-2005, 09:58 PM
  Pelican Parts Technical Article Directory    Reply With Quote #20 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
