Hi,
According to Hayes my 924 ignition coil should have resistances of : 1 - 1.3 ohm between term. 1 and 15 5.5 - 8 kOhm btween term. 1 and 4 but is measured 3.3 Ohm and 8.6 kOhm... is this still okay, because its some more then the 'allowed' range. should i replace it? thx! |
Disconnect all the other wires and check it again.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
I did measure with all wires lose, so there was nothing connected while measuring!!!
