Question No voltage on ignition coil #15 ?!
When i turn my 924 ignition "on", there should be 12 volts on one side of my ignition coil (term #15), but i measure no voltage!!
when i remove the wire from the coil and measure on the wire itself, i do measure a voltage of 12V.
but when i put it back on, the voltage is gone again. i did measure if there is any current flowing but thats not the case.
help! no voltage is no spark is not running!
what can be the problem that the power is gone once i put the wire on the coil?
(i measured the coil and thats in my other post about the ignition coil)
thnx in advance!
Old 07-03-2005, 11:18 PM
carsonmx114's Avatar
i was just looking at that circuit for another post and that power comes from a relay it may be that the contacts in your relay are not making a good connection and when the coil requires amperage the circuit is opening at the relay.
86' 951
k26/27 hybrid turbo
01' audi s4
98' TDI jetta
96' 933tt AWD LS1
Old 07-04-2005, 09:25 AM
SoCal Driver's Avatar
What year 924? Early 80's have an ignition modual and balast resistors between the voltage from the ignition switch and the over ride from the starter.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-04-2005, 09:36 AM
Check the electrical diagrams found here:
http://www.pelicanparts.com/944/electrical/944_electrical_diagrams.htm
Old 07-04-2005, 09:40 AM
