adjusting clutch... refresh my memory please
the engagement point of the clutch in our 944 is about 1/3 the way off of the floor. i need to bring the engagement point back down to be closer to the floor. which direction do i turn the little nut again when looking at the front of the car... clockwise right?
thanks! obin |
Correct - clockwise to delay the clutch engagement (move it closer to the floor)
Welcome back, long time, no see AFJuvat |
wow, where is this little nut? I need to do this, mine engages too late
The shaft on the back of the clutch pedal - loosen the locknut, and rotate the shaft clockwise (if you were facing the front of the car)
AFJuvat |
obin SmileWavy |
| All times are GMT -8. The time now is 11:38 PM. |
