Help 83 944
83 944 will only idle will not rev. Had to jump relay for fuel for it to run any suggestions
Old 07-23-2005, 08:12 AM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
1.) Replace Relay
2.) Replace Fuel Filter
Check fuel pressure at end of the rail after replacing filter. I suspect you will also need a new FPR.
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 07-23-2005, 08:57 AM
SoCal Driver's Avatar
That is DME/fuel pump relay. Check fuel pump fuse.
Use www.clarks-garage.com as a reference for the 944.
Also www.frwilk.com
Change your timing and balance belt.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-23-2005, 11:45 AM
Bad throttle position switch...
gb
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 07-23-2005, 03:57 PM
