Send a message via AIM to jakemu24
rpm vs fuel efficiency
Right now my car idles at ~900 rpm, like normal. I think my motor mounts are dieing so the car rumbles a bit. One day I put my foot on the gas and let the car run at 1000 rpm. The rumble went away and I think the car ran more fuel efficient. I looked at the mpg gauge under the tack and it confirmed the fact that the engine ran better. I'm considering adjusting the idle screw to make the car run at 1000 rpm. Are there any reasons why i shouldn't make this change?
1985.5 Stone Grey 944-SOLD
1987 Yellow 951- For Sale
Old 07-28-2005, 08:03 AM
SoCal Driver's Avatar
Fuel use is from load (torq) demand.
Replace the engine mounts.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-28-2005, 09:20 AM
hmmmmm...........bad motor mounts make the engine rumble??Learn something new everyday
89 944 na Dove Blue Metalic
2000 chevy silverado
2000 chevy 454 dually black
79 GMC short bed 4x4
4 quarter horses
89 acura legend GS sedan
Old 07-29-2005, 06:32 PM
See if you can stick most of your hand between the cross member and the oil pan. From the front. Engine cold.
If you can barely get your finger tips in the gap then you need engine mounts.
Old 07-29-2005, 09:27 PM
would it be bad if i raised the idle speed anyways?
Old 07-30-2005, 07:33 AM
Ornery Bastard
It would be a pointless fix that only masks a more serious problem. Don't do it.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 07-30-2005, 11:55 AM
I can stick my fingers between the engine and the crosmember from the back. here's a pic
Old 07-30-2005, 04:57 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Good deal. Collect your cookie.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 07-30-2005, 05:12 PM
