shake with that milk please
I've read enough threads to convince me that my oil cooler seals are gone, (oil in coolant only) but in addition to the seals some threads have also recommended changing the
Oil pressure relief valve?
'O' ring?
seal?
use the alignment tool?
Should all be changed?
Thanks as always for the input
'88 944
Old 08-07-2005, 11:11 AM
SoCal Driver's Avatar
All of the above. Don't let the mix go much longer. You will over heat the car and ruin all of the radiator hoses.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-07-2005, 06:17 PM
Thanks SoCal for the feedback
'88 944
Old 08-08-2005, 07:02 PM
Back from Beyond
Depending on how much oil you've got in your coolant, you may want to clean out the header tank and coolant hoses. I used garden variety paint thinner to clean the header tank and flushed the rest.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 08-10-2005, 10:36 AM
