TNT25169's Avatar
Send a message via AIM to TNT25169
Steering rack advice?
I am reinstalling my steering rack after replacing my oil pan gasket and many other parts along the way. Does anyone have any advice as far as getting the u-joint onto the rack. My splines are all lined up and I have it about 1/3 of the way on and this is just a pain in my butt. I have used a screwdriver to spread the u-joint but I am still having a very hard time getting the u-joint all the way onto the rack. Any advice?
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 08-09-2005, 05:46 PM
SoCal Driver's Avatar
Take the bolt out???
Make sure the coupler is goning back on the same location (rotation) it came out. I've had to use a long drift to coax a reluctant coupling back onto the steering rack.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-09-2005, 07:54 PM
TNT25169's Avatar
bolts out and coupler is going onto exactly where I marked with nail polish. What's a drift?
www.apartabove.com
Old 08-09-2005, 09:38 PM
A soft metal punch. Usually brass. I have a couble of brass shafts of various diameters and lengths. 3/8" to 1/2" diameter and ten to 20 inches long. Keeps from peaning over the steel part from hitting it directly with a hard punch.
Is the rack bolted in? If it is you may have to unbolt it.
Old 08-09-2005, 09:51 PM
rudidelange's Avatar
It should slide in without any problems if the U-Bolt is spread slightly with a screwdriver - misaligned?
1983 944 RHD Original. Uses all my spare cash!
1947 Morris Sold
1972 Benz Sold
1975 Benz Sold
1976 Benz Sold
1977 Benz Sold
Old 08-10-2005, 08:14 AM
Back from Beyond
You could use a cold chisel and brass hammer to spread coupler open. That should give you enough clearance, but it's kinda brutal and a screwdriver should be used first. Also, I usually slide the rack into the coupler before I attach any crossmember bolts. That way you can mess with the alignment of the rack.
While you're down there, bench press the car a couple of times!
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 08-10-2005, 10:10 AM
