auh auh is offline
auh's Avatar
Send a message via AIM to auh
swaping heads
About how long and how hard is it to change the head if I bought a new one? and while I'm at it changing the water pump?
How can I tell if my car has the updated water pump or not?
1974 914 1.8 Sold...
1984 944 my baby...more of a pain in the @$$ than takin' it with a cucumber, but I still love it. THE CAR YOU PERVS!!!!!!!!!!!!
1990 Nissan 240sx fastback aka Japanese 944
Old 08-11-2005, 11:13 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
If it has the guard between the water pump pulley and the idler, it should be the updated one.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 08-11-2005, 11:16 AM
Cars & Coffee Killer
legion's Avatar
Totally OT...
Keep your eyes open for a red 951, I might pass through Deerfield on the way up to Lake Geneva this weekend!
5 liters of VVT fury now
-Chris
Old 08-11-2005, 11:17 AM
ae1969's Avatar
Send a message via ICQ to ae1969
If its your first head........ a weekend outta do it.
The waterpump is really the only thing that may cause you grief.
It all depends on how corroded the bolts are.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 08-11-2005, 11:31 AM
oh god, the bolts... sweet lord did I cause myself problems there.
Do a search for my water pump ordeal and hopefully you'll be able to learn from my stupidity!
Old 08-11-2005, 12:07 PM
Back from Beyond
Swapping a head is fairly straightforward, but be aware that the bolts holding the cam tower can get tricky. The ones you see along the exhaust manifold are only half the story. The rest are under the hex-head caps on the cam cover. See Haynes. Also, try to loosen them each a little at a time, otherwise the pressure put on them by the cam/lifters can put a firm grip on whichever bolt comes out last. Then the bolt pops loose and disappears into the cam box. Also make sure to tilt the cam box in such as way as to keep the lifters in place. They gotta go back where they came from. That said, it's a fun way to spend an afternoon.
Water pump bolts - for heaven's sake, don't overtorque them! That's about it, except for the whole timing belt trip. But by now you're probably aware of that.
What I wanna know is, can a good head gasket be reinstalled? I'd think not.
Since you've got the head off, you've got a good opportunity to r&r vacuum lines, aux air valve and anything else hiding under the intake.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 08-11-2005, 12:22 PM
No, a head gasket can't be reused. They're a one-use-only item. When you tighten it the first time, you crush it a specific amount through the torquing sequence. it crushes to fill-in and seal the microscopic differences in the 2 surfaces. the second time, you'll never get all the parts EXACTLY in the same spot. In addition, you would need a different torquing procedure, which doesn't exist. if you torque with the regular procedure, you'll overstress the head studs, or pull out threads.
Mike
'92 968
'01 VW Jetta TDi
Old 08-11-2005, 12:46 PM
