-   -   How can I stop a dash crack? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/235290-how-can-i-stop-dash-crack.html)
ICD 08-09-2005 03:31 PM
I have a 944 with a perfect dash, until now.
A hairline crack has started at one of the vents by the windshield. It started towards the interior of the car and is less than 1/4" wide.
Any suggestions? Super glue? Anything?
yellowline 08-09-2005 03:57 PM
Keep the car from getting too hot inside? I'm sure significant expansion and contraction play a part in dash cracking.
pokey 08-09-2005 05:06 PM
Don't use Super Glue. It doesn't play well with the foam backing or the vinyl skin. I am not sure what would work well, though.
944 Ecology 08-09-2005 05:47 PM
About the only thing that you can do is ask Superman to circle the globe counterclockwise, setting up a time warp so that all time stands still.
Short of that, get a dash cap or a dash carpet. The crack will still propagate, but you won't be able to see it.
gb
livewirevoodoo 08-09-2005 06:36 PM
No!!!!
Chia Dash is a ripoff! I used it once, a few weeks before putting my car away for the winter.
Don't chia-fy the dash unless you plan on bi-monthly pruning.
http://www.jimhillmedia.com/mb/image...%20Bug%207.jpg
carsontc 08-09-2005 06:54 PM
wow...once again this forum has saved me from certain disaster
my FR Wilks do it yourself Chia Dash Cover is going on eBay !
http://cgi.ebay.com/ONE-FULL-POUND-OF-CHIA-SEEDS_W0QQitemZ5604824828QQcategoryZ101965QQrdZ1QQ cmdZViewItem
carsontc 08-09-2005 07:17 PM
actually I have used and do like some of the SEM product line
but has anyone used:
http://www.sem.ws/product.php?product_id=123
or
http://www.sem.ws/tip.php?tip_id=4
with any luck?
seaboltman 08-09-2005 07:53 PM
Originally posted by livewirevoodoo
No!!!!
that is the coolest picture i've seen in a while... any clue where to find a high res version?
Moneyguy1 08-10-2005 10:37 AM
Years ago I bought a dash cap from Accuform. After a few years it develpoed a slight warp. I asked Accuform how to repair this and they sent me a full replacement unit. Any way you figure it, the dash cap looks a lot better than a cracked dashboard. Just follow the instructions to the letter. Very little adhesive (supplied) is used, around the edges to give the plastic room to expand and contract.
Porsche-O-Phile 08-10-2005 04:53 PM
I have yet to find a dash cap that doesn't sound cheap and tinny/hollow when you tap on it though. Maybe some expanda-foam stuff under it would help?
Moneyguy1 08-10-2005 06:46 PM
You mean the original doesn't look and sound cheap?
bigyagi 08-10-2005 09:39 PM
ha ha, you got that one right on, bob !!
Moneyguy1 08-11-2005 09:20 AM
I always wonder what happened to the steel dashboard that had a removable padded cover on it. Seems as if it would add lateral stiffness to the body where it is needed the most. Most older cars that I have worked on were built that way, not out of compressed cardboard with a leatherette cover a few microns thick.
I have also noticed that the "grain" on most 944 interior parts is different part to part, resulting in a strange look.
Slam 08-11-2005 01:09 PM
To do a dash cover right, pull the dash so you can get good pressure evenly on the cover, Otherwise it'll always look like an add-on. Mine does. My wife took out her dash before gluing the cover on and it looks a thousand times better than mine.
