caliper castings?
Hey guys,
i was wondering if its hard to take off the caliper castings? Would it require a long time or is it relatively easy. also, if i take these off, is it hard to realign the calipers with the rotors? Thanks
84' 944 |
Easy. Use a 19 mm socket or wrench to remove the bolts.
Easy to align the calipers with the rotors. gb
Good luck, George Beuselinck |
where are these bolts located?
84' 944 |
They are on the back side of the caliper, with the heads towards the center of the car.
gb
