LinkBack Thread Tools Rating: Thread Rating: 5 votes, 3.40 average.
roadierfl's Avatar
944 NA idle speed....what should it be?
I'm idling at 1200 RPM and it seems a little high......my 911 idled around 900 and my 914 idled around 850. If it is high, how can I lower it?
1969 Mercedes 280/8 114k miles
[RETIRED]1985.5 944 NA just under 300k miles
[RETIRED]1972 914/6 190k miles
[RETIRED]1997 951 180k miles
Old 08-16-2005, 09:28 AM
livewirevoodoo's Avatar
1200 for a cold start is reasonable. Once at operating temp 850 and 900 both sound right
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 08-16-2005, 09:31 AM
at first start up1200 is fine, but once u warm it up, it should do 850-900
84' 944
roadierfl's Avatar
It's always around 1200 though......
How do I adjust it?
Thanks guys
Old 08-16-2005, 09:47 AM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
sounds like it may be an AFM going out - mine has idled high when the AFM was gone and when I replaced it, it was fine.
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Old 08-16-2005, 11:20 AM
SoCal Driver's Avatar
Check for a vacuum leak in the large rubber L hose between the throttle body and the AFS. Could be one of the vacuum lines that run off of it.
To adjust the idle of a late model 944 you have to short out term B to term C on the test plug then adjust the idle.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-16-2005, 12:06 PM
Cars & Coffee Killer
legion's Avatar
What is the idle on a 951? Mine idles at 750.
5 liters of VVT fury now
-Chris
Old 08-16-2005, 12:21 PM
Old 08-16-2005, 12:24 PM
BananaClip's Avatar
Send a message via Yahoo to BananaClip
Mine idles at 900-950 cold, but when its warmed up it's 1200.
keep the dream alive!
1988 944 NA (purple)
Old 08-16-2005, 09:06 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
if it idles at 1200, adjust the flat-head screw that sits below and to the left of the throttle cam assembly, on the throttle body. You just turn this screw until you get the desired idle.
If the idle goes back up to 1200 even after the adjustment, you have a vaccuum leak.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 08-16-2005, 09:48 PM
roadierfl's Avatar
Thanks, that did the trick
Now all I have to do is get the exhaust manifold leak sorted out
Old 08-17-2005, 08:28 AM
rudidelange's Avatar
BananaClip
My car has a similar problem - low at idle at start and higher when hot.
Have you solved it?
I have checked about everything - my aux air valve does not close 100% when hot, could this be the problem?
1983 944 RHD Original. Uses all my spare cash!
1947 Morris Sold
1972 Benz Sold
1975 Benz Sold
1976 Benz Sold
1977 Benz Sold
Old 08-18-2005, 07:46 AM
