Steve PH's Avatar
Help ! Door pin replacement....
The drivers door is off, the hinges are reasonably easy to get at but I cannot drift out the pins. Just to make sure I'm not going about this the wrong way can anyone confirm which way up the pins go in/come out?
I'm guessing that the top hinge pin, needs to be pushed up to get it out and the bottom one is the opposite?
Thanks in advance.
Old 09-10-2005, 09:42 AM
SoCal Driver's Avatar
Never messed with the pins. Door stop strap yes.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-11-2005, 12:16 AM
